[GRASS-dev] [GRASS GIS] #3622: r.out.gdal export in USGSDEM format takes very long time and finally crashes
GRASS GIS trac at osgeo.org
Fri Aug 17 07:06:53 PDT 2018
crashes
  Reporter:  dido        |      Owner:  grass-dev@…
      Type:  defect      |     Status:  new
  Priority:  critical    |  Milestone:
 Component:  Raster      |    Version:  7.4.0
Resolution:              |   Keywords:  r.out.gdal export USGSDEM long time
                         |  crashes
       CPU:  x86-64      |   Platform:  MSWindows 7
Comment (by dnewcomb):
 Are you shooting for the ASCII USGSDEM format as described at
 https://www.gdal.org/frmt_usgsdem.html?
 From the message:
 >Driver <USGSDEM> does not support direct writing. Using MEM driver for
 intermediate >dataset.
 Do you have enough memory to hold a 4 billion pixel raster in memory on
 the computer?
 See also
 https://www.gdal.org/frmt_mem.html
 Not sure if either the MEM driver or the USGS DEM format can handle 4
 billion pixels. Is there a reason that you can't use GeoTIFF ( up to 4GB
 file Size)for the output file or GeoTIFF with the BIGTIFF option? ( up to
 18,000 petabytes for a single file)
 If you are determined to do ascii file output, why not r.out.ascii,
 https://grass.osgeo.org/grass74/manuals/r.out.ascii.html ?
 >WARNING: Precision loss: Raster map
 <BGMdem_8x8m_holes_filled_feathered at PERMANENT> of >type DCELL to be
 exported as Int16. This can be avoided by using Float64.
 If you are going to truncate to integer, it might be better to use the
 int() or round() functions in r.mapcalc prior to exporting.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3622#comment:1>
