[GRASS-dev] [GRASS GIS] #3623: wxGUI Layer Manager: changed display name of layer gets lost when layer properties are changed
    trac at osgeo.org
    Fri Aug 17 07:53:27 PDT 2018
 Reporter:  mlennert                  |      Owner:  grass-dev@…
     Type:  defect                    |     Status:  new
 Priority:  normal                    |  Milestone:  7.4.2
Component:  wxGUI                     |    Version:  svn-trunk
 Keywords:  wxGUI layer display name  |        CPU:  Unspecified
 Platform:  Unspecified               |
 In the wxGUI Layer Manager, one can change the display name (right-click
 -> Rename). This can be very useful when displaying different subsets of a
 same map as different layers and using display names to identify which is
 which.
 However, whenever I change the properties of a layer, the display name
 falls back to the original map name and I have to rename it again. IMHO
 this is a bug and it should be up to the user to decide to rename the
 layer if necessary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3623>
