[GRASS-dev] [GRASS GIS] #3466: v.to.db: check if column exists before running
trac at osgeo.org
Tue Aug 28 13:55:28 PDT 2018
Reporter: sbl | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.6.0
Component: Vector | Version: svn-releasebranch74
Resolution: | Keywords: v.to.db,column
CPU: All | Platform: All
Comment (by mmetz):
Replying to [comment:8 veroandreo]:
> Replying to [comment:6 pvanbosgeo]:
> > +1 for creating columns if they don't exist (and the flag to determine
if overwriting is OK) as default behavior
> +1
+1
Just for clarification:
* if the column(s) exist, require --overwrite
* if the column(s) do not exist, create them with the appropriate type
Additionally,
* if the column(s) exist, check if the column type is correct
Ticket URL: <https://trac.osgeo.org/grass/ticket/3466#comment:9>
