[GRASS-dev] [GRASS GIS] #3466: v.to.db: check if column exists before running
GRASS GIS trac at osgeo.org
Wed Aug 29 00:33:05 PDT 2018
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  normal       |  Milestone:  7.6.0
 Component:  Vector       |    Version:  svn-releasebranch74
Resolution:               |   Keywords:  v.to.db,column
       CPU:  All          |   Platform:  All
Comment (by mlennert):
 Replying to [comment:9 mmetz]:
 > Replying to [comment:8 veroandreo]:
 > > Replying to [comment:6 pvanbosgeo]:
 > > > +1 for creating columns if they don't exist (and the flag to
 determine if overwriting is OK) as default behavior
 > > +1
 > +1
 > Just for clarification:
 > * if the column(s) exist, require --overwrite
 > * if the column(s) do not exist, create them with the appropriate type
 > Additionally,
 > * if the column(s) exist, check if the column type is correct
 So, you are suggesting no -c flag as in v.rast.stats ? Should that flag in
 v.rast.stats be deprecated in order to maintain coherence ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3466#comment:10>
