[GRASS-dev] [GRASS GIS] #3617: save display to image button broken
trac at osgeo.org
Wed Aug 29 08:27:56 PDT 2018
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.4.2
Component: wxGUI | Version: unspecified
Resolution: | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by veroandreo):
Just in case the message is not readable from the image, here's the ascii
text provided by Carol Garzon:
GRASS 7.4.1 (panamania):~ > d.mon wx1
GRASS 7.4.1 (panamania):~ > d.vect Bufpuntos
d.vect completo.
GRASS 7.4.1 (panamania):~ > d.out.file output=intento format=png
GRASS 7.4.1 (panamania):~ > Traceback (most recent call last):
File "/Applications/GRASS-7.4.1.app/Contents/Resources/lib/python2.7
/site-packages/wx/core.py", line 2158, in Notify
self.notify()
File
"/Applications/GRASS-7.4.1.app/Contents/Resources/gui/wxpython/mapdisp/main.py",
line 590, in watcher
self.mapFrm.GetMap().GetLayersFromCmdFile()
File
line 137, in GetLayersFromCmdFile
self.saveToFile.emit(cmd=utils.split(dCmd))
File
"/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pydispatch/signal.py",
line 229, in emit
dispatcher.send(signal=self, *args, **kwargs)
File
"/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pydispatch/dispatcher.py",
line 349, in send
**named
File
"/Applications/GRASS-7.4.1.app/Contents/Resources/etc/python/grass/pydispatch/robustapply.py",
line 60, in robustApply
return receiver(*arguments, **named)
File
line 548, in <lambda>
self.Map.saveToFile.connect(lambda cmd: self.mapFrm.DOutFile(cmd))
File
"/Applications/GRASS-7.4.1.app/Contents/Resources/gui/wxpython/mapdisp/frame.py",
line 667, in DOutFile
filetype, ltype = self._prepareSaveToFile()
File
line 802, in _prepareSaveToFile
filetype, ltype = GetImageHandlers(img)
File
"/Applications/GRASS-7.4.1.app/Contents/Resources/gui/wxpython/gui_core/dialogs.py",
line 1832, in GetImageHandlers
for h in image.GetHandlers():
AttributeError: 'Image' object has no attribute 'GetHandlers'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:9>
