[GRASS-dev] [GRASS GIS] #3617: save display to image button broken
GRASS GIS trac at osgeo.org
Fri Aug 31 14:36:57 PDT 2018
  Reporter:  cmbarton     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  blocker      |  Milestone:  7.4.2
 Component:  wxGUI        |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by cmbarton):
 This might be very easy to fix it.
 I just found out that in the same version of trunk where save output does
 not work for 2D, it works fine for 3D. We just need to use the 3D code
 (and add some additional output formats) for this to work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3617#comment:10>
