[GRASS-dev] [GRASS GIS] #3632: Add a function to read parameters from a file to the parser
trac at osgeo.org
Thu Aug 30 17:56:51 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 8.0.0
Component: Parser | Version: unspecified
Resolution: | Keywords: g.parser options parameters file
CPU: | long CLI
Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
Replying to [comment:2 mmetz]:
> Using the example
> r.slope.aspect elevation=dtm slope=dtm_slope aspect=dtm_aspect -n
> what is the advantage of the proposed approach over a file that contains
exactly this line and executing this file? This is already working and
handled by the OS.
I'm thinking about these three points:
1) There is no command line length limitation as the line or lines are
processed directly by the parser.
When I have a long r.series input:
> r.series in=map1900,map1901,...,map2100 out=slope meth=slope
I need to switch to `file` instead of `input`.
> cat input.txt
map1900
map1901
map2100
> r.series file=input.txt out=slope meth=slope
That of course assumes that `file` was implemented. In case of having the
parameter file, I need to switch to that while still using `input`.
> cat params.txt
out=slope
meth=slope
> r.series --parameter-file=params.txt
2) The scripting is replaced with configuration. This "command line
scripting" is OS-depended. You want a short line, but backslashes won't
work in GUI Console (and on MS Win?). Escaping is done in different ways.
In other words, the format is actually not well defined, so unless you
already know "command line scripting" on your OS, this will be cumbersome.
Another syntax related thing are comments which again could have a clearly
defined syntax (`#` in Bash versus `REM` in CMD).
So the following ways of storing the parameters as a command with
indentation and backslash which will work well in unix-like command line
but not necessarily elsewhere (which is something we need to explain to
the user),
r.series input=map2001,map2002,dummy,dummy,map2005,map2006,dummy,map2008 \
output=res_slope,res_offset,res_coeff
method=slope,offset,detcoeff
would become, e.g., the following YAML file:
input:
- map2001
- map2002
- dummy
- dummy
- map2005
- map2006
- dummy
- map2008
output:
- res_slope
- res_offset
- res_coeff
method:
- slope
- offset
- detcoeff
Here the advantage is for modules which are implementing some
model/simulation which usually have a lot of parameters, e.g.
G7:r.sim.water (which has over 20 parameters) or G7:r.topmodel (which
actually requires a "parameters file").
3) This untangles the module from its parameters (splits the "command"
into module name and parameters). This brings additional questions such
as: Should we extend the format by adding module name or multiple modules
and than read that using the `grass` command creating effectively a new
API (similarly to e.g. PDAL JSON pipelines)? However, what I'm thinking
about now is the advantage of storing the parameters separately from the
command itself and than reusing them repetitively (in an interactive
command line or a script) while being able to override or complete the
parameters when needed. You can do the same with enough of Python, but
this would be native.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3632#comment:3>
