[GRASS-dev] [GRASS GIS] #3632: Add a function to read parameters from a file to the parser
trac at osgeo.org
Thu Aug 30 18:17:45 PDT 2018
Reporter: wenzeslaus | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: normal | Milestone: 8.0.0
Component: Parser | Version: unspecified
Resolution: | Keywords: g.parser options parameters file
CPU: | long CLI
Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
Replying to [comment:1 mlennert]:
> I definitely would not want it to replace the file option.
I don't know if to replace it or not. The thing is that we are adding file
option to more and more modules. If the parameter file is available, then
not only all modules but all their options too have a solution for the
length limit of the command line arguments. That doesn't rule out the file
option for convenience and alternative syntax, but you don't needed to
implemented just because you need it once.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3632#comment:4>
