[GRASS-dev] [GRASS GIS] #3634: r.horizon: segmentation fault/bus error when raster using wrong geographical coordinates
GRASS GIS trac at osgeo.org
Fri Aug 31 10:28:39 PDT 2018
  Reporter:  lbartoletti  |      Owner:  grass-dev@…
      Type:  defect       |     Status:  closed
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.4.0
Resolution:  fixed        |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Changes (by mmetz):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"73219" 73219]:
 #!CommitTicketReference repository="" revision="73219"
 r.horizon: check if coordinates are within the current region, fixes #3634
Ticket URL: <https://trac.osgeo.org/grass/ticket/3634#comment:1>
