[GRASS-dev] [GRASS GIS] #3634: r.horizon: segmentation fault/bus error when raster using wrong geographical coordinates
trac at osgeo.org
Fri Aug 31 06:21:37 PDT 2018
Reporter: lbartoletti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.0
Keywords: | CPU: Unspecified
Platform: Unspecified |
While trying to use the tool on a SRTM (N45E007), I was confronted with a
segmentation and bus error. My mistake was inverting lat/lon...
Here's my procedure to reproduce it.
> r.horizon elevation=N45E007 coordinates=45.737698,7.361012 step=5
Note: In latitude-longitude coordinate system specify buffers in degree
unit
39437 bus error (core dumped) r.horizon elevation=N45E007
> r.horizon elevation=N45E007 coordinates=45.737698,7.361012 step=0
direction=215 bufferzone=1 maxdistance=5000
unit
39574 segmentation fault (core dumped) r.horizon elevation=N45E007
Ticket URL: <https://trac.osgeo.org/grass/ticket/3634>
