[GRASS-dev] [GRASS GIS] #613: clean_temp: not safe for concurrent use
GRASS GIS trac at osgeo.org
Fri Aug 31 20:55:48 PDT 2018
  Reporter:  hamish   |      Owner:  grass-dev@…
      Type:  defect   |     Status:  new
  Priority:  normal   |  Milestone:  7.6.0
 Component:  Startup  |    Version:  6.4.0 RCs
Resolution:           |   Keywords:  clean_temp init grass.py
       CPU:  All      |   Platform:  All
Changes (by wenzeslaus):
 * keywords:  clean_temp => clean_temp init grass.py
 * milestone:  6.4.6 => 7.6.0
Comment:
 This still might be an issue. `clean_temp()` (which calls `clean_temp`) is
 called on [source:grass/trunk/lib/init/grass.py?rev=73199#L2037 line 2040]
 while mapset is set and ready later on
 [source:grass/trunk/lib/init/grass.py?rev=73199#L2079 line 2087]. Same in
 7.0 and trunk (7.7). (Now I have second thoughts about closing #1286, but
 if it is an issue (location being set, but possibly garbage), it is really
 this one anyway.)
Ticket URL: <https://trac.osgeo.org/grass/ticket/613#comment:3>
