[GRASS-dev] [GRASS GIS] #1665: Grass SVN (51807) doesn’t launch: Path '…/<UNKNOWN>/<UNKNOWN>' doesn't exist
trac at osgeo.org
Fri Aug 31 21:12:10 PDT 2018
exist
Reporter: vince | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.7
Component: Startup | Version: svn-trunk
Resolution: fixed | Keywords:
CPU: OSX/Intel | Platform: MacOSX
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
The trunk (7.5/7.7) starts for me with no `~/.grass7` directory (a state
which generates `<UNKNOWN>/<UNKNOWN>` internally) on Linux. I did some
improvements in error handling there and there might have been more
changes I don't recall. Currently, a nice error message is reported when
starting in text mode (no GUI at all) and not providing mapset in the
command line.
ERROR: Unable to start GRASS GIS. You have the choice to:
- Launch the graphical user interface with the '-gui' switch
grass75 -gui
- Launch with path to the location/mapset as an argument
grass75 /path/to/location/mapset`
- Create a location with '-c' and launch in its PERMANENT mapset
grass75 -c EPSG:number /path/to/location
grass75 -c geofile /path/to/location
- Create manually the GISRC file (/home/vpetras/.grass7/rc)
- Use '--help' for further options
grass75 --help
See also: https://grass.osgeo.org/grass75/manuals/helptext.html
Exiting...
Closing as fixed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1665#comment:9>
