[GRASS-dev] [GRASS GIS] #396: add NULL and MASK support to i.smap
GRASS GIS trac at osgeo.org
Wed Dec 5 03:37:29 PST 2018
  Reporter:  dylan        |      Owner:  grass-dev@…
      Type:  enhancement  |     Status:  new
  Priority:  minor        |  Milestone:  7.8.0
 Component:  Raster       |    Version:
Resolution:               |   Keywords:  i.smap
       CPU:  Other        |   Platform:  All
Changes (by marisn):
 * milestone:  6.4.6 => 7.8.0
Comment:
 This still is a case.
 To make things worse – if NULL cells are inside a block, result differs
 significantly from a different sized block without NULL cells. Thus maps
 with NULL values should use as small blocks as possible.
Ticket URL: <https://trac.osgeo.org/grass/ticket/396#comment:2>
