[GRASS-dev] [GRASS GIS] #3702: r.in.wms: examples return errors
GRASS GIS trac at osgeo.org
Wed Dec 5 04:51:36 PST 2018
 Reporter:  lucadelu     |      Owner:  grass-dev@…
     Type:  defect       |     Status:  new
 Priority:  normal       |  Milestone:  7.6.0
Component:  Raster       |    Version:  unspecified
 Keywords:  r.in.wms     |        CPU:  Unspecified
 Platform:  Unspecified  |
 Hi, I'm testing r.in.wms examples from the manual page but most of them
 return errors
 r.in.wms url="https://tiles.maps.eox.at/wms?" layers=s2cloudless
 output=sentinel2 format=png
 ERROR 1: KEA was compiled against GDAL 2.2, but the current library
 version is 2.3
 Downloading data from WMS server...
 Reprojecting raster...
 version is 2.3
 ERROR 1: Cannot guess driver for
 /home/lucadelu/grassdata/nc_spm_08/test/.tmp/geowork/14177.0
 ERROR: gdalwarp failed
 r.in.wms url="http://ows.mundialis.de/services/service?" layer=TOPO-WMS
 output=topo format=png
 version is 2.3
 RuntimeError: module compiled against API version 0xc but this version of
 numpy is 0xa
   File "/home/lucadelu/compilati/grass_trunk/dist.x86_64-pc-linux-
 gnu/scripts/r.in.wms", line 241, in <module>
     sys.exit(main())
 gnu/scripts/r.in.wms", line 227, in main
     fetched_map = wms.GetMap(options, flags)
 gnu/etc/r.in.wms/wms_base.py", line 215, in GetMap
     self.temp_map = self._download()
 gnu/etc/r.in.wms/wms_drv.py", line 194, in _download
     tile_dataset = self._pct2rgb(temp_tile, temp_tile_pct2rgb)
 gnu/etc/r.in.wms/wms_drv.py", line 285, in _pct2rgb
     src_data = src_band.ReadAsArray(0, iY, src_ds.RasterXSize, 1)
   File "/usr/lib/python2.7/dist-packages/osgeo/gdal.py", line 2598, in
 ReadAsArray
     import gdalnumeric
   File "/usr/lib/python2.7/dist-packages/osgeo/gdalnumeric.py", line 1, in
 <module>
     from osgeo.gdal_array import *
   File "/usr/lib/python2.7/dist-packages/osgeo/gdal_array.py", line 17, in
 <module>
     _gdal_array = swig_import_helper()
   File "/usr/lib/python2.7/dist-packages/osgeo/gdal_array.py", line 16, in
 swig_import_helper
     return importlib.import_module('_gdal_array')
   File "/usr/lib/python2.7/importlib/__init__.py", line 37, in
 import_module
     __import__(name)
 ImportError: No module named _gdal_array
 r.in.wms url="http://watzmann-geog.urz.uni-heidelberg.de/cached/osm"
 layers=osm_auto:all output=osm format=png
 version is 2.3
 ERROR: Unable to fetch capabilities from
        <http://watzmann-geog.urz.uni-heidelberg.de/cached/osm?>. Reason:
        Proxy Error
Ticket URL: <https://trac.osgeo.org/grass/ticket/3702>
