[GRASS-dev] [GRASS GIS] #3706: TGRASS tests failing
trac at osgeo.org
Thu Dec 13 22:44:24 PST 2018
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.6.0
Component: Temporal | Version: svn-trunk
Keywords: t.vect.algebra, t.rast3d.algebra, | CPU: Unspecified
t.rast.algebra, t.rast.accdetect, |
t.rast.series, t.vect.extract, t.connect, |
t.rast3d.extract, t.rast.extract, |
t.rast.aggregate, t.rast.gapfill, |
t.rast.contour, t.rast.univar, |
t.rast3d.univar, t.rast.accumulate, t.info, |
t.rast.what |
Platform: Unspecified |
At time a list of TGRASS tests are failing:
* grass.exceptions.FatalError: Wrong type of input A
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.vect.algebra/test_vector_algebra/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast3d.algebra/test_raster3d_algebra/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.algebra/test_raster_algebra_granularity/index.html
* ERROR: Space time raster dataset <B> not found
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.accdetect/test_simple/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.accdetect/test.t.rast.accdetect.reverse/index.html
* mismatch values (key, reference, actual): [('end_time', '2001-05-01
00:00:00', u"'2001-05-01 00:00:00'"), ('start_time', '2001-02-01
00:00:00', u"'2001-02-01 00:00:00'")]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.series/test_series/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.vect.extract/test_vect_extract/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.connect/test_distr_tgis_db_raster/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.connect/test_distr_tgis_db_raster3d/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.connect/test_distr_tgis_db_vector/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast3d.extract/test_extract/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.extract/test_extract/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.aggregate/test_aggregation_absolute/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.aggregate/test_aggregation_relative/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.aggregate/test_aggregation_absolute_parallel/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.gapfill/test_gapfill/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.contour/test_convert/index.html
* AttributeError: 'NoneType' object has no attribute 'second'
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.accdetect/test.t.rast.accdetect/index.html
* AssertionError: reference argument is not a string
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.univar/test_univar/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast3d.univar/test_univar/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.accumulate/test_accumulation/index.html
* UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 2: ordinal not in range(128)
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.info/test.t.info/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/temporal/t.rast.what/test_what/index.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3706>
