[GRASS-dev] [GRASS GIS] #3707: vector module tests failing
GRASS GIS trac at osgeo.org
Thu Dec 13 22:47:46 PST 2018
 Reporter:  neteler                              |      Owner:  grass-dev@…
     Type:  defect                               |     Status:  new
 Priority:  normal                               |  Milestone:  7.6.0
Component:  Vector                               |    Version:  svn-trunk
 Keywords:  v.what, v.db.select, v.profile,      |        CPU:  Unspecified
  v.rast.stats, v.select                         |
 Platform:  Unspecified                          |
 At time some vector module tests are failing:
   * AssertionError: actual argument is not a string
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.what/test_vwhat_ncspm/index.html
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.db.select/test_v_db_select/index.html
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.profile/test_v_profile/index.html
   * AssertionError: reference argument is not a string
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/scripts/v.rast.stats/test_v_rast_stats/index.html
   * ERROR: Only numeric column type is supported
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/lib/python/gunittest/test_assertions_vect/index.html
   * ERROR: Vector map <bridges> not found
 http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2018-12-13-08-00/report_for_nc_basic_spm_grass7_nc/vector/v.select/test_v_select/index.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3707>
