[GRASS-dev] [GRASS GIS] #3715: v.out.ogr segfault with GPKG output
GRASS GIS trac at osgeo.org
Wed Dec 19 07:50:29 PST 2018
 Reporter:  vince      |      Owner:  grass-dev@…
     Type:  defect     |     Status:  new
 Priority:  normal     |  Milestone:
Component:  Default    |    Version:  7.4.2
 Keywords:  v.out.ogr  |        CPU:  x86-64
 Platform:  MacOSX     |
 This happens while using GRASS in the QGIS toolbox.
 A r.contour operation runs fine, but when the result is about to be saved
 in a GPKG file, v.out.ogr crashes.
 Backtrace:
 1   libsqlite3.dylib         dbMallocRawFinish + 17
 2   libsqlite3.dylib         sqlite3FindFunction + 886
 3   libsqlite3.dylib         sqlite3CreateFunc + 499
 4   libsqlite3.dylib         sqlite3_create_function_v2 + 488
 5   libspatialite.7.dylib   register_spatialite_sql_functions + 68
 6   libspatialite.7.dylib   spatialite_init_ex + 52
 7   libgdal.20.dylib         OGRSQLiteBaseDataSource::InitNewSpatialite()
 + 302
 8   libgdal.20.dylib         GDALGeoPackageDataset::InstallSQLFunctions()
 + 19
 9   libgdal.20.dylib         GDALGeoPackageDataset::Create(char const*,
 int, int, int, GDALDataType, char**) + 485
 10  libgdal.20.dylib         OGRGeoPackageDriverCreate(char const*, int,
 int, int, GDALDataType, char**) + 159
 11  libgdal.20.dylib         GDALDriver::Create(char const*, int, int,
 int, GDALDataType, char**) + 1063
 12  libgdal.20.dylib         OGR_Dr_CreateDataSource + 47
 13  v.out.ogr                    main + 3564
 I have upgraded to spatialite 5.0.0 beta0 in hope that would solve the
 problem, but no dice. Also, I run GDAL 2.3.2.
 Saving as Shapefile works fine, though, so this is a mere inconvenience
 rather than a roadblock.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3715>
