[GRASS-dev] [GRASS GIS] #3714: v.out.ogr: segfault with -n
trac at osgeo.org
Thu Dec 20 10:53:52 PST 2018
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.4.4
Component: Vector | Version: unspecified
Resolution: fixed | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by mmetz):
Replying to [ticket:3714 neteler]:
> At time -n crashes the command (tested also in G74 and later):
> GRASS 7.7.svn (nc_spm_08):~ > v.out.ogr in=zipcodes_wake type=area
out=filename.shp format=ESRI_Shapefile -n
> Segmentation fault (core dumped)
Note that the example is wrong because `output` must be a OGR datasource,
not a OGR layer, and `filename.shp` is a OGR layer. You can specify a OGR
layer name with `output_layer`.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3714#comment:4>
