[GRASS-dev] problem with reading KML
Anna Petrášová
kratochanna at gmail.com
Mon Feb 5 11:52:06 PST 2018
On Mon, Feb 5, 2018 at 2:30 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> On lundi 5 février 2018 10:04:25 CET Anna Petrášová wrote:
>> Hi,
>> I ran into a weird problem with KML with 3D line, v.import failed when
>> reprojecting it:
>> WARNING: pj_transform() failed: latitude or longitude exceeded limits
>> This happened with GRASS 7.4.0 64bit (GDAL 2.2.3) on Windows 10, on my
>> Ubuntu with latest GRASS it works (GDAL 2.2.1). Weird thing is that I
>> installed the same version of GRASS on Windows 10 virtual machine and
>> there it worked without problems.
> I can indeed replicate with the LIBKML driver on Windows (probably by libkml
> itself), and this is specific to this combination. From testing, it appears
> that the presence of newline+tabulations without spaces between coordinate
> triplets is the cause of the issue, where libkml doesn't detect properly the
> start of the x coordinate of the new triplet and mangles it with the z of
> the previous one.
> As a workaround, you might define OGR_SKIP=LIBKML as configuration option to
> exclude the LIBKML driver and use the "old" KML one that has not that issue.
> Or edit the file to replace tabulations by spaces.
Thank you for the analysis, I created a ticket for that
https://trac.osgeo.org/gdal/ticket/7231
Anna
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
