[GRASS-dev] External providers in QGIS
Helmut Kudrnovsky
hellik at web.de
Tue Feb 6 14:12:24 PST 2018
Hi Paolo,
pcav wrote
> Hi all,
> following the discussion on qgis-dev ML:
> https://lists.osgeo.org/pipermail/qgis-developer/2018-January/051701.html
> it has been proposed to remove all external providers (namely OTB,
> already removed, GRASS, and SAGA) from Processing in QGIS2 (GDAL will
> remain as QGIS cannot be built without). This raised a number of
> concerns, so PSC decided not to rush removing them from the upcoming 3.0
> release, and to open a wider discussions about this, involving all the
> interested parties, to find an optimal solution.
> If volunteers outside QGIS core team, ideally from the respective
> backends, could take the maintenance of these providers, not much would
> change for the end user. If not, this will mean effectively missing
> hundreds of algs from QGIS.
> I personally propose to reinstate the OTB plugin with Rashad (from OTB)
> as maintainer.
> QGIS.ORG will seek to support any decision made with funding where
> possible.
> Looking forward for your feedback.
> All the best.
> Paolo Cavallini
thanks for the follow up on this discussion.
Is there already a concrete technical documention of requirements, methods,
API, interface etc by QGIS how alg providers work/should work/be maintained?
This may ease and accelerate to start a discussion in the communities of
algs providers like OTB, GRASS, SAGA and others how to proceed in this
inter-project challenge.
this is part of QGIS success and this question has also to be answered by
the QGIS community.
This may be an indication that OSGeo's inter-project communication should be
proactively improved in the future.....
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
