[GRASS-dev] [GRASS GIS] #3494: r.thin crashes after 84 passes
trac at osgeo.org
Tue Feb 13 07:16:02 PST 2018
Reporter: pitstop | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: 7.4.0
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 7
Comment (by mlennert):
Replying to [ticket:3494 pitstop]:
> Hi Community,
> I wanted to use r.thin on a raster map before r.to.vect on the result
but r.thin crashes after 84 passes every time. Smaller number of
iterations run without any problems. I was able to reproduce the error by
using r.thin on the elevation.dem from the Spearfish data set.
While this should probably be handled more gracefully, could you explain
what you are trying to do with r.thin ? Why would you run r.thin on a DEM
? r.thin is meant to thin raster lines (represented by some form of
discrete pixel values) to single pixel width so as to make their
vectorisation possible. Running it on a raster map with a continuous
variable doesn't make sense in my understanding.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3494#comment:1>
