[GRASS-dev] [GRASS GIS] #3494: r.thin crashes after 84 passes
trac at osgeo.org
Tue Feb 13 13:06:24 PST 2018
Reporter: pitstop | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: 7.4.0
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 7
Changes (by mmetz):
* component: Raster => wxGUI
Comment:
Replying to [comment:1 mlennert]:
> Replying to [ticket:3494 pitstop]:
> > Hi Community,
> > I wanted to use r.thin on a raster map before r.to.vect on the result
but r.thin crashes after 84 passes every time. Smaller number of
iterations run without any problems. I was able to reproduce the error by
using r.thin on the elevation.dem from the Spearfish data set.
> While this should probably be handled more gracefully,
On the OS command line
g.region -p rast=elevation.dem
r.thin in=elevation.dem out=elevation.dem.thin it=1000
finishes successfully after 229 passes.
Apparently the problem is that the gui can't handle the messages produced
by r.thin, i.e. the gui crashes, not r.thin.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3494#comment:2>
