[GRASS-dev] Problems installing the r.pi suite using g.extension [was: Re: [GRASS-user] LSMetrics - addon development]
Moritz Lennert mlennert at club.worldonline.be
Fri Feb 16 03:47:30 PST 2018
Moving this over to grass-dev...
On 16/02/18 10:14, Markus Metz wrote:
> On Fri, Feb 16, 2018 at 10:05 AM, Markus Neteler <neteler at osgeo.org
> <mailto:neteler at osgeo.org>> wrote:
>  > On Fri, Feb 16, 2018 at 9:42 AM, Markus Metz
>  > <markus.metz.giswork at gmail.com
> <mailto:markus.metz.giswork at gmail.com>> wrote:
>  > > I can't reproduce with your compiler flags. A wild guess: in
> draw.c:L3 try
>  > > to replace inline with static
>  > Yes, this helps. I didn't submit the change, will you do that?
> done in r72247
Even though everything seems to install alright, I get an error message:
g.extension r.pi
Fetching <r.pi> from GRASS GIS Addons repository (be patient)...
Compiling...
Installing...
make[1]: *** No rule to make target 'install'.  Stop.
Updating addons metadata file...
Installation of <r.pi> successfully finished
I imagine this due to the fact that I run GRASS directly from the source
directory and not from ?
But when I try to install it using the system-wide installation (Debian
package, grass-dev is installed), I get:
g.extension r.pi
Compiling...
/usr/bin/ld: cannot open output file
/usr/lib/grass74/lib/libgrass_rpi.7.4.0.so: Permission denied
collect2: error: ld returned 1 exit status
make[1]: *** [/usr/lib/grass74/lib/libgrass_rpi.7.4.0.so] Error 1
/bin/sh: 1: cannot create /usr/lib/grass74/error.log: Permission denied
make: *** [r.pi.library] Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
i.e. it tries to install the lib into the system-wide installation
directory, not the user .grass7/addons directory.
Removing also doesn't seem to work:
g.extension r.pi op=remove -f
ERROR: Unable to remove file
        '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.corr.mw.1'
        '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.lm.1'
        '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.grow.1'
        '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.rectangle.1'
Extension <r.pi> successfully uninstalled.
but
ls .grass7/addons/bin/r.pi*
.grass7/addons/bin/r.pi.corearea   .grass7/addons/bin/r.pi.graph
.grass7/addons/bin/r.pi.nlm.circ
.grass7/addons/bin/r.pi.csr.mw	   .grass7/addons/bin/r.pi.graph.dec
.grass7/addons/bin/r.pi.nlm.stats
.grass7/addons/bin/r.pi.energy	   .grass7/addons/bin/r.pi.graph.pr
.grass7/addons/bin/r.pi.odc
.grass7/addons/bin/r.pi.energy.pr  .grass7/addons/bin/r.pi.graph.red
.grass7/addons/bin/r.pi.prob.mw
.grass7/addons/bin/r.pi.enn	   .grass7/addons/bin/r.pi.import
.grass7/addons/bin/r.pi.prox
.grass7/addons/bin/r.pi.enn.pr	   .grass7/addons/bin/r.pi.index
.grass7/addons/bin/r.pi.searchtime
.grass7/addons/bin/r.pi.export	   .grass7/addons/bin/r.pi.neigh
.grass7/addons/bin/r.pi.searchtime.mw
.grass7/addons/bin/r.pi.fnn	   .grass7/addons/bin/r.pi.nlm
.grass7/addons/bin/r.pi.searchtime.pr
I guess we need some more work on how to handle these suites...
Moritz
