[GRASS-dev] Problems installing the r.pi suite using g.extension [was: Re: [GRASS-user] LSMetrics - addon development]
Markus Metz
markus.metz.giswork at gmail.com
Fri Feb 16 07:56:40 PST 2018
On Fri, Feb 16, 2018 at 12:47 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> Moving this over to grass-dev...
> On 16/02/18 10:14, Markus Metz wrote:
>> On Fri, Feb 16, 2018 at 10:05 AM, Markus Neteler <neteler at osgeo.org
<mailto:neteler at osgeo.org>> wrote:
>> > On Fri, Feb 16, 2018 at 9:42 AM, Markus Metz
>> > <markus.metz.giswork at gmail.com <mailto:markus.metz.giswork at gmail.com>>
wrote:
>> > > I can't reproduce with your compiler flags. A wild guess: in
draw.c:L3 try
>> > > to replace inline with static
>> > Yes, this helps. I didn't submit the change, will you do that?
>> done in r72247
> Even though everything seems to install alright, I get an error message:
> g.extension r.pi
> Fetching <r.pi> from GRASS GIS Addons repository (be patient)...
> Compiling...
> Installing...
> make[1]: *** No rule to make target 'install'. Stop.
> Updating addons metadata file...
> Installation of <r.pi> successfully finished
> I imagine this due to the fact that I run GRASS directly from the source
directory and not from ?
It seems that there is no mechanism to install a library as addon. It is
also possible that something is missing in the Makefile for r.pi.library
because that library is unknown to the GRASS make system.
> But when I try to install it using the system-wide installation (Debian
package, grass-dev is installed), I get:
> g.extension r.pi
> Compiling...
> /usr/bin/ld: cannot open output file /usr/lib/grass74/lib/
libgrass_rpi.7.4.0.so: Permission denied
> collect2: error: ld returned 1 exit status
> make[1]: *** [/usr/lib/grass74/lib/libgrass_rpi.7.4.0.so] Error 1
> /bin/sh: 1: cannot create /usr/lib/grass74/error.log: Permission denied
> make: *** [r.pi.library] Error 2
> ERROR: Compilation failed, sorry. Please check above error messages.
> i.e. it tries to install the lib into the system-wide installation
directory, not the user .grass7/addons directory.
the addons directory is supposed to hold executables and scripts, not
libraries. At least I could not find a mechanism in the grass startup
script where LD_LIBRARY_PATH is adjusted to also include some directory
within the addons directory. I am not sure if it is worth the trouble to
modify the addons mechanism to support addon libraries, particularly if
only the r.pi suite is affected.
Markus M
> Removing also doesn't seem to work:
> g.extension r.pi op=remove -f
> ERROR: Unable to remove file
> '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.corr.mw.1'
> '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.lm.1'
> '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.grow.1'
> '/home/mlennert/.grass7/addons/docs/man/man1/man1/r.pi.rectangle.1'
> Extension <r.pi> successfully uninstalled.
> but
> ls .grass7/addons/bin/r.pi*
> .grass7/addons/bin/r.pi.corearea .grass7/addons/bin/r.pi.graph
.grass7/addons/bin/r.pi.nlm.circ
> .grass7/addons/bin/r.pi.csr.mw .grass7/addons/bin/r.pi.graph.dec
.grass7/addons/bin/r.pi.nlm.stats
> .grass7/addons/bin/r.pi.energy .grass7/addons/bin/r.pi.graph.pr
.grass7/addons/bin/r.pi.odc
> .grass7/addons/bin/r.pi.energy.pr .grass7/addons/bin/r.pi.graph.red
.grass7/addons/bin/r.pi.prob.mw
> .grass7/addons/bin/r.pi.enn .grass7/addons/bin/r.pi.import
.grass7/addons/bin/r.pi.prox
> .grass7/addons/bin/r.pi.enn.pr .grass7/addons/bin/r.pi.index
.grass7/addons/bin/r.pi.searchtime
> .grass7/addons/bin/r.pi.export .grass7/addons/bin/r.pi.neigh
.grass7/addons/bin/r.pi.searchtime.mw
> .grass7/addons/bin/r.pi.fnn .grass7/addons/bin/r.pi.nlm
.grass7/addons/bin/r.pi.searchtime.pr
> I guess we need some more work on how to handle these suites...
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180216/9ff62fb5/attachment.html>
