[GRASS-dev] Problems installing the r.pi suite using g.extension [was: Re: [GRASS-user] LSMetrics - addon development]
Maris Nartiss maris.gis at gmail.com
Fri Feb 16 23:42:48 PST 2018
2018-02-16 17:56 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
> the addons directory is supposed to hold executables and scripts, not
> libraries. At least I could not find a mechanism in the grass startup script
> where LD_LIBRARY_PATH is adjusted to also include some directory within the
> addons directory. I am not sure if it is worth the trouble to modify the
> addons mechanism to support addon libraries, particularly if only the r.pi
> suite is affected.
Then what is the solution? Moving all library code to each module?
> Markus M
Māris.
