[GRASS-dev] Problems installing the r.pi suite using g.extension [was: Re: [GRASS-user] LSMetrics - addon development]
Moritz Lennert mlennert at club.worldonline.be
Tue Feb 20 02:52:36 PST 2018
On 17/02/18 08:42, Maris Nartiss wrote:
> 2018-02-16 17:56 GMT+02:00 Markus Metz <markus.metz.giswork at gmail.com>:
>> the addons directory is supposed to hold executables and scripts, not
>> libraries. At least I could not find a mechanism in the grass startup script
>> where LD_LIBRARY_PATH is adjusted to also include some directory within the
>> addons directory. I am not sure if it is worth the trouble to modify the
>> addons mechanism to support addon libraries, particularly if only the r.pi
>> suite is affected.
> Then what is the solution? Moving all library code to each module?
Would it be possible to force all functions in the library to be inline
? Would that be a solution ?
Moritz
