[GRASS-dev] Untangling geoPAT installation when updating GRASS version
Pierre Roudier pierre.roudier at gmail.com
Fri Feb 23 13:10:08 PST 2018
Thanks Dylan,
I did install using `sudo sh install.sh grass72` -- then `sudo sh
install.sh grass74` after my Grass version got updated to 7.4
Cheers,
P
On 23 February 2018 at 18:41, Dylan Beaudette <dylan.beaudette at gmail.com>
wrote:
> Howdy Pierre!
> In my experience, the GeoPat modules need to know where several things
> are located, including (I think) parts of the GRASS source code. Have
> a look through the install.sh code:
> http://sil.uc.edu/gitlist/geoPAT/blob/stable/install.sh
> I was able to get these modules up and running by invoking install.sh like
> this:
> sh install.sh grass75
> ... where "grass75" is the binary compiled from grass_trunk. The
> install.sh code seemed to find the source code it needed and worked
> without issue.
> How did you install / upgrade the Geopat modules? Could it be that
> install.sh is "finding" the old source code / headers? Is there a
> package for both GRASS binaries and development files?
> Dylan
> On Thu, Feb 22, 2018 at 7:28 PM, Pierre Roudier
> <pierre.roudier at gmail.com> wrote:
> > Hi,
> > I've been compiling the geoPAT extensions for GRASS from
> > At the time I was running GRASS 7.2.2 installed from the Ubuntu GIS
> > repository, but since this repo updated to GRASS 7.4, I have the
> following
> > issue:
> > GRASS 7.4.0 (modis_lst_2015):~ > p.sig.polygons --help
> > ERROR: Module built against version $Revision: 70617 $ but trying to use
> >        version $Revision: 70829 $. You need to rebuild GRASS GIS or
> >        untangle multiple installations.
> > [Raster MASK present]
> > Any pointers about how to resolve the version tangling? I've tried
> > recompiling geoPAT, but that didn't work.
> > Cheers,
> > Pierre
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180224/8a7d0fa5/attachment.html>
