[GRASS-dev] Untangling geoPAT installation when updating GRASS version
Dylan Beaudette
dylan.beaudette at gmail.com
Thu Feb 22 21:41:38 PST 2018
Howdy Pierre!
In my experience, the GeoPat modules need to know where several things
are located, including (I think) parts of the GRASS source code. Have
a look through the install.sh code:
http://sil.uc.edu/gitlist/geoPAT/blob/stable/install.sh
I was able to get these modules up and running by invoking install.sh like this:
sh install.sh grass75
... where "grass75" is the binary compiled from grass_trunk. The
install.sh code seemed to find the source code it needed and worked
without issue.
How did you install / upgrade the Geopat modules? Could it be that
install.sh is "finding" the old source code / headers? Is there a
package for both GRASS binaries and development files?
Dylan
On Thu, Feb 22, 2018 at 7:28 PM, Pierre Roudier
<pierre.roudier at gmail.com> wrote:
> Hi,
> I've been compiling the geoPAT extensions for GRASS from
> At the time I was running GRASS 7.2.2 installed from the Ubuntu GIS
> repository, but since this repo updated to GRASS 7.4, I have the following
> issue:
> GRASS 7.4.0 (modis_lst_2015):~ > p.sig.polygons --help
> ERROR: Module built against version $Revision: 70617 $ but trying to use
> version $Revision: 70829 $. You need to rebuild GRASS GIS or
> untangle multiple installations.
> [Raster MASK present]
> Any pointers about how to resolve the version tangling? I've tried
> recompiling geoPAT, but that didn't work.
> Cheers,
> Pierre
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
