[GRASS-dev] [GRASS GIS] #3502: v.proj location not set in dialog
GRASS GIS trac at osgeo.org
Sun Feb 25 10:30:57 PST 2018
 Reporter:  balagates        |      Owner:  grass-dev@…
     Type:  defect           |     Status:  new
 Priority:  normal           |  Milestone:
Component:  wxGUI            |    Version:  7.4.0
 Keywords:  v.proj location  |        CPU:  OSX/Intel
 Platform:  MacOSX           |
 In the Source tab for the v.proj dialog are three entry fields - location,
 mapset and name.  The pulldown list for location seems appropriate and you
 can select an item, however, this does not update the dialog.  You can
 tell because 1) the status dialog at the bottom still shows
 "location=<required>" and the subsequent entry field pulldown lists are
 not populated as you would expect.  A workaround is to type the location
 name in manually in the text box.  Then everything works as expected.
 The other pulldowns, mapset and name, in this dialog seems to work
 properly and update the dialog when an element in the pulldown is
 selected.
 This is a new behavior for me in 7.4.0.  It worked as I expected in 7.2.2.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3502>
