[GRASS-dev] [GRASS GIS] #3503: Map Display control button highlights do not reflect active mode
trac at osgeo.org
Sun Feb 25 10:47:14 PST 2018
Reporter: balagates | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.4.0
Keywords: map display zoom button highlight | CPU: OSX/Intel
Platform: MacOSX |
The active mode highlights for a number of button controls do not reflect
the actual state. The highlights for Pointer, Select Vector Features,
Query, Pan, Zoom In, Zoom Out seem to toggle individually each time a
button is pressed. I believe that pressing one of these buttons should
un-highlight all others in the group.
A simple example is first press the Zoom out then the Zoom in buttons. On
my installation both buttons are now highlighted. If I switch screens and
come back I cannot be certain which mode is active.
The workaround is every time you are uncertain what mode is active just
press the button again.
This problem existed in 7.2.2 also.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3503>
