[GRASS-dev] OSGeo Login required to get code
Markus Neteler
neteler at osgeo.org
Mon Feb 26 06:49:42 PST 2018
Am 26.02.2018 3:42 nachm. schrieb "Vaclav Petras" <wenzeslaus at gmail.com>:
Do you mean on your computer where you entered credentials in past to get
write access? That would be the difference.
Right!
> The
two computers I mentioned were a fresh install without someone's
credentials as well as the Docker test.
No idea, seems independent, but appeared at a similar time (the certificate
issue may not happen outside of Docker, not sure).
> Or, it was a temporary problem?
I can't try the other computers now, but in Docker, I still get the same
result:
docker run -it --rm ubuntu
apt update -y
apt install -y subversion
svn checkout https://svn.osgeo.org/grass/grass/trunk
Error validating server certificate for 'https://svn.osgeo.org:443':
- The certificate is not issued by a trusted authority. Use the
fingerprint to validate the certificate manually!
Certificate information:
- Hostname: *.osgeo.org
- Valid: from Apr 28 00:00:00 2016 GMT until May 1 23:59:59 2019 GMT
- Issuer: SSL.com DV CA, www.ssl.com, SSL.com, US
- Fingerprint: 56:50:0D:63:0F:47:10:92:7A:3A:B5:A9:83:F8:97:92:FE:D6:19:95
(R)eject, accept (t)emporarily or accept (p)ermanently?
Could it be that the pool of certificate authorities is outdated in your
docker?
Is it up to date?
A trunk/misc/m.measure/main.c
A trunk/misc/m.cogo/TODO
A trunk/misc/m.cogo/Makefile
A trunk/testsuite/vector/v.in.gps_test.sh
A trunk/testsuite/Makefile
A trunk/testsuite/README
Authentication realm: <https://svn.osgeo.org:443> OSGeo Login
Password for 'root':
I'm traveling so I cannot easily check now... maybe someone else could try
with a docker generated from a different distro?
Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180226/af233409/attachment.html>
