[GRASS-dev] GSoC Project
sharry gill sharrygill5656 at gmail.com
Tue Feb 27 01:29:58 PST 2018
Hello Luca,
There will be a tool, in which the user enters the name of the module, and
select the flags and parameters of the modules, and select which test to be
done.
after selecting these option, the user click "Create Test", then their will
be a python file generated on the desktop, by using the python file user
can test the module.
And When the user will enter the module name, the window will extend and at
the side it will show manual of the module.
Thank You
Supreet Singh
https://singhsupreet.github.io/
On Tue, Feb 27, 2018 at 4:57 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> [image: Boxbe] <https://www.boxbe.com/overview> Luca Delucchi (
> lucadeluge at gmail.com) is not on your Guest List
> <https://www.boxbe.com/approved-list?tc_serial=37048451360&tc_rand=998831450&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&key=NUJwHJ6HohHD0jZ6Mh7canc5e8dzdjLHqa4rzVKjMUY%3D&token=NhcfaCw1%2BDpyVy6bdqx8MQ8BVbKyxAngJkRW%2BRVOHlT7gOUKVuNJHn8XTeO10bs1>
> | Approve sender
> <https://www.boxbe.com/anno?tc_serial=37048451360&tc_rand=998831450&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&key=NUJwHJ6HohHD0jZ6Mh7canc5e8dzdjLHqa4rzVKjMUY%3D&token=NhcfaCw1%2BDpyVy6bdqx8MQ8BVbKyxAngJkRW%2BRVOHlT7gOUKVuNJHn8XTeO10bs1>
> | Approve domain
> <https://www.boxbe.com/anno?tc_serial=37048451360&tc_rand=998831450&utm_source=stf&utm_medium=email&utm_campaign=ANNO_MWTP&utm_content=001&dom&key=NUJwHJ6HohHD0jZ6Mh7canc5e8dzdjLHqa4rzVKjMUY%3D&token=NhcfaCw1%2BDpyVy6bdqx8MQ8BVbKyxAngJkRW%2BRVOHlT7gOUKVuNJHn8XTeO10bs1>
> On 19 February 2018 at 14:40, sharry gill <sharrygill5656 at gmail.com>
> wrote:
> > Hello,
> Hi Sharry,
> > I created a draft of GSoC Proposal: Link To Proposal.
> > In the proposal is have a project idea:
> > Title: Tool to create Automatic Module test writer in Python
> > Description of the idea :
> > 1) First, there is an option of entering the name of module
> > 2) After that, there will some options regarding which test the user
> wants
> > to write. (for eg:assertMinMax, RasterFitsUnivar etc)
> > 3)Then there will be options for selecting flags and maps.
> > 4)Then the user will click "create the test" then a python file will be
> > provided to the user which contains the test.
> > SAMPLE MOCKUP:  Link to image
> please you should improve your description, it could be useful to
> create test automatically from each modules or execute test from
> manuals [0]
> Please ask if you have questions.
> > Can I know which mentor will be mentoring me?
> If the description will be improved I could co-mentoring
> > Thank You
> > Supreet Singh
> [0] https://trac.osgeo.org/grass/wiki/GSoC/2018#
> Toolsforgeneratingunittestsfromexamplesinthemanual
> ciao
> Luca
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180227/2eaa9cc4/attachment.html>
