[GRASS-dev] [GRASS GIS] #3462: Allow setting environment variables in grass startup script
GRASS GIS trac at osgeo.org
Tue Feb 27 13:26:08 PST 2018
  Reporter:  mankoff      |      Owner:  martinl
      Type:  defect       |     Status:  assigned
  Priority:  major        |  Milestone:  7.2.3
 Component:  Startup      |    Version:  7.2.2
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by mankoff):
 Thank you for making the change! I'm sorry I did not thank you and
 test/confirm the change previously. However - I cannot test it. I compile
 GRASS dev versions on a Linux machine, but because OS X is only partially
 supported, I have never gotten a full build/test environment working on OS
 X. I need to wait until one of the package managers provides a version
 with your updates. I recently upgraded to 7.4.0 but had to downgrade to
 7.2.2 because 7.4.0 does not work with QGIS. I *think* you can close this
 ticket (again, based on visual inspection of the change).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:21>
