[GRASS-dev] [GRASS GIS] #3462: Allow setting environment variables in grass startup script
trac at osgeo.org
Tue Feb 27 14:17:36 PST 2018
Reporter: mankoff | Owner: martinl
Type: defect | Status: closed
Priority: major | Milestone: 7.2.3
Component: Startup | Version: 7.2.2
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: MacOSX
Changes (by neteler):
* status: assigned => closed
* resolution: => fixed
Comment:
Replying to [comment:21 mankoff]:
> Thank you for making the change! I'm sorry I did not thank you and
test/confirm the change previously. However - I cannot test it. I compile
GRASS dev versions on a Linux machine, but because OS X is only partially
supported, I have never gotten a full build/test environment working on OS
X.
Did you try this?
https://grasswiki.osgeo.org/wiki/Compiling_on_MacOSX_using_homebrew
> I need to wait until one of the package managers provides a version with
your updates. I recently upgraded to 7.4.0 but had to downgrade to 7.2.2
because 7.4.0 does not work with QGIS.
It meanwhile does:
https://github.com/qgis/QGIS/pull/6394
* present in QGIS 3.0.0: https://github.com/qgis/QGIS/blob/release-
3_0/cmake/FindGRASS.cmake
* present in QGIS 2.18.17: https://github.com/qgis/QGIS/blob/release-
2_18/cmake/FindGRASS.cmake
> I *think* you can close this ticket (again, based on visual inspection
of the change).
Backport?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3462#comment:22>
