[GRASS-dev] [GRASS GIS] #2764: corrupt data written to FCELL and DCELL rasters, hard to re-produce
trac at osgeo.org
Mon Jan 8 13:15:16 PST 2018
Reporter: dylan | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.3
Component: Raster | Version: unspecified
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by dylan):
Replying to [comment:28 mmetz]:
> This is a very simple r.mapcalc expression. You should be able to
trigger the error by simply creating a number of maps in parallel with
r.mapcalc, after that (serially) testing the outputs with r.univar. With
r.mapcalc in daily-rad.sh, you are running several independent instances
of r.mapcalc in parallel. With daily-rad.sh called by beam-rad-at-tile.sh
you are not testing if GRASS is thread-safe, instead you are testing if
your OS, filesystem and hard drive can handle multiple simultaneous IO
requests. Please check your system messages and the health of your hard
drives (e.g. with smartctl) first, before you proceed.
Yeah, that is what I thought and what the original test scripts basically
perform. As stated in [https://trac.osgeo.org/grass/ticket/2764#comment:2
my update] circa 2 years ago, these tests run fine on both the RAID1 and
SSD on this machine.
I don't see any troubling messages reported by `dmesg` or `smrtctl`. Note
that I don't have any issues with any other GRASS commands, or (as far as
I can tell) general usage on this machine. I only see these errors when
working with GRASS commands that:
* take a long time to run: `r.sun` or `t.rast.mapcalc` ([http://osgeo-
org.1560.x6.nabble.com/Error-reading-raster-data-for-row-xxx-only-when-
using-r-series-and-t-rast-series-td5229569.html e.g. a couple of years
ago])
* operate on moderately large, floating-point maps
* are done in parallel, either via GNU `parallel` or as implemented in
the temporal suite of modules
...hence the extreme difficulty in recreating the errors or further
debugging.
For the record, I have been getting corrupt rows using LZ4 compression in
1/8 attempts vs. 1/2 attempts when using ZLIB compression.
Next error I'll re-compile without openmp (not using it, but just in case)
and -g -Wall CFLAGS.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2764#comment:29>
