[GRASS-dev] [GRASS GIS] #2755: Commandline switch "/S" is not working anymore
trac at osgeo.org
Wed Jan 10 02:22:52 PST 2018
Reporter: derseppel | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Installation | Version: 7.0.1
Resolution: | Keywords: wingrass
CPU: Unspecified | Platform: MSWindows 7
Comment (by derseppel):
This bug is more than 2 years old and nothing happend.
I can't imagine that it is that hard to implement an if statement that
checks the /S parameter and skips the VC++ installation.
Sorry for being grumpy. I don't know the code and have never done things
like this. Just doing some batch and powershell scripting.
Does the Installer write an install.log? If so where can I find it? You
could check which is the last line before VC++ gets installed and kill the
Install-Process when this line is reached. Grass Gis is successfully
installed before.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2755#comment:23>
