[GRASS-dev] [GRASS GIS] #2755: Commandline switch "/S" is not working anymore
GRASS GIS trac at osgeo.org
Wed Jan 10 01:53:22 PST 2018
  Reporter:  derseppel     |      Owner:  grass-dev@…
      Type:  defect        |     Status:  new
  Priority:  normal        |  Milestone:  7.0.6
 Component:  Installation  |    Version:  7.0.1
Resolution:                |   Keywords:  wingrass
       CPU:  Unspecified   |   Platform:  MSWindows 7
Comment (by hellik):
 Replying to [comment:21 aaronsmiley]:
 > It sounds like fixing this isn’t easy, and/or the developers don’t see a
 one-size-fits-all solution.
 winGRASS is based upon the OSGeo4W environment.
 as you can see in [http://download.osgeo.org/osgeo4w/x86/release/msvcrt/
 OSGeo4W 32bit MS runtimes] or
 [http://download.osgeo.org/osgeo4w/x86_64/release/msvcrt/ OSGeo4W 64bit MS
 runtimes], these are the msvcrt needed to run winGRASS, and there are
 differences between 32bit and 64bit.
 GRASS dependencies are sometimes updated/recompiled with newer VC++
 versions, then new msvcrt dependencies are added.
 it's really hard to test which msvcrt are available or already installed
 on win 7, 8 or 10 boxes. MS windows doesn't provide a systematic way to
 test/check this.
 as already mentioned in some comments above, there are some NSIS
 functionalities to skip some installer steps when /S mode. code
 snippets/PR are very welcome.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2755#comment:22>
