[GRASS-dev] r.series with file option - too many files open
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Jan 15 08:27:56 PST 2018
On 1/15/18 4:39 PM, Markus Metz wrote:
> On Mon, Jan 15, 2018 at 4:12 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com <mailto:p.vanbreugel at gmail.com>> wrote:
> > Hi devs,
> > I am trying to run r.series with a large number of input maps
> (5000). Given the large number of input maps, I am using the 'file'
> option.
> > GRASS 7.5.svn (latlon):~ > r.series output=speciescount method=sum
> file=test.txt
> > I get the warning:
> > WARNING: G__open(read): Unable to open
> > '/home/paulo/Data/HASdata/latlon/redlist/cellhd/Eulemur_fulvus':
> > Too many open files
> > ERROR: Error reading reclass file for raster map <Eulemur_fulvus>
> > Eulemur_fulvus is the 511th file on the list. From the help file, I
> thought that using the file option will prevent one from hitting open
> files limit and the size limit of command line arguments. Am I
> misunderstanding the r.series helpfile?
> the file option prevents too long command lines: instead of providing
> hundreds of map names as input, only one file with the map names is
> provided
> the manual is wrong:
> Use the /file/ option to analyze large amount of raster maps without
> hitting open files limit and the size limit of command line arguments.
> must be
> Use the -z flag to analyze large amount of raster maps without hitting
> open files limit and the /file/ option to avoid hitting the size limit
Ah, yes, I totally forgot about that flag. Thanks (also Anna and
Veronica). Perhaps somebody with write permission can correct his in the
manual page?
> Markus M
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org <mailto:grass-dev at lists.osgeo.org>
> > https://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180115/4376989c/attachment.html>
