[GRASS-dev] [GRASS GIS] #3486: v.in.ogr: default format in online manual
GRASS GIS trac at osgeo.org
Wed Jan 31 23:19:48 PST 2018
  Reporter:  martinl      |      Owner:  grass-dev@…
      Type:  task         |     Status:  new
  Priority:  normal       |  Milestone:  7.4.1
 Component:  Docs         |    Version:  unspecified
Resolution:               |   Keywords:  v.out.ogr
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by mmetz):
 Replying to [comment:3 martinl]:
 > Replying to [comment:1 mmetz]:
 > > Earlier versions of GDAL also support GPKG. Is it possible that the
 build server has a minimal GDAL installation built without SQLite3? The
 GeoPackage driver needs SQLite3.
 > There is SQLite support included
 > martinl at osgeo6:~$ ogrinfo --formats | grep GPKG
 > martinl at osgeo6:~$ ogrinfo --formats | grep SQLite
 >   -> "SQLite" (read/write)
 > It seems to me that GPKG driver has been introduced in GDAL 1.11.
 Probably we should fix G74:v.out.ogr to reflect also this version.
 The GPKG driver is only the default if it is available, therefore the
 manual on the build server is correct.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3486#comment:4>
