[GRASS-dev] [GRASS GIS] #3486: v.in.ogr: default format in online manual
trac at osgeo.org
Wed Jan 31 23:30:14 PST 2018
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.4.1
Component: Docs | Version: unspecified
Resolution: | Keywords: v.out.ogr
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:2 neteler]:
> Replying to [comment:1 mmetz]:
> > Replying to [ticket:3486 martinl]:
> > > Any chance to update GDAL to version 2 on build server?
> > Earlier versions of GDAL also support GPKG. Is it possible that the
build server has a minimal GDAL installation built without SQLite3? The
GeoPackage driver needs SQLite3.
> Yes, the grass.osgeo.org server is meanwhile a bit antique:
> neteler at osgeo6:~$ cat /etc/issue
> Debian GNU/Linux 8 \n \l
> neteler at osgeo6:~$ gdal-config --version
> 1.10.1
> neteler at osgeo6:~$ which gdal-config
> /usr/bin/gdal-config
> Anyone with more Debian experience than me: is there a better GDAL
binary package we could install? Or do I/MartinL have to compile GDAL from
scratch?
There are no gdal packages in jessie-backports, so I'm afraid that
compilation is necessary.
Jessie is old-stable. The current Debian stable release (stretch) has gdal
2.12.
Following stable releases would probably be enough to have relatively up
to date packages...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3486#comment:5>
