[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Mon Jul 9 13:00:42 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by cmbarton):
I attached the file as requested. Also, here is the command I used:
m.nviz.image elevation_map=elevation at PERMANENT
color_map=elevation at PERMANENT resolution_fine=1 height=800 perspective=20
output=elevation format=tif size=640,480
I'll comment out line 221, recompile and let you know.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:42>
