[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Mon Jul 9 13:21:04 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hcho):
 Replying to [comment:42 cmbarton]:
 > I attached the file as requested. Also, here is the command I used:
 > m.nviz.image elevation_map=elevation at PERMANENT
 color_map=elevation at PERMANENT resolution_fine=1 height=800 perspective=20
 output=elevation format=tif size=640,480
 > I'll comment out line 221, recompile and let you know.
 FYI, ppm would be better because it directly prints out size in plaintext.
 Thanks for testing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:43>
