[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Mon Jul 9 16:50:45 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by cmbarton):
Replying to [comment:51 hcho]:
> Replying to [comment:49 cmbarton]:
> > I will try this. However, we know that nviz, using OpenGL works fine
and that the nviz interface can save an OpenGL image to a file. Can't the
code for m.nviz.image just be lifted from the main nviz code?
> Yeah.. maybe, it's better to rewrite m.nviz.image in Python because nviz
uses wx.glcanvas internally. Not sure about that.
Maybe a good idea. Then there would not be as much separate software
maintenance needed to keep the interactive and command line versions
functional and in sync across multiple platforms
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:53>
