[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
trac at osgeo.org
Mon Jul 9 21:28:06 PDT 2018
Reporter: guano | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 7.0.4
Resolution: | Keywords:
CPU: Unspecified | Platform: MacOSX
Comment (by hcho):
Only Windows defines double buffering; that's why Linux works without
buffer swapping because it has only one buffer. BUT, glGetError() still
returns GL_INVALID_OPERATION according to https://www.khronos.org/registry
/OpenGL-Refpages/gl4/html/glReadBuffer.xhtml. Probably, that's why some
Linux drivers and MacOS don't work at all.
Windows is also broken because nviz draws to the back buffer, but it reads
from the front buffer without buffer swapping.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:54>
