[GRASS-dev] Dependencies for wxGUI and wx monitors
Nikos Alexandris nik at nikosalexandris.net
Wed Jul 11 09:42:12 PDT 2018
>2018-07-07 3:00 GMT+03:00 Nikos Alexandris <nik at nikosalexandris.net>:
>> * Nikos Alexandris <nik at nikosalexandris.net> [2018-07-07 01:20:52 +0200]:
>>> Dears,
>>> I have trouble launching wx monitors via `wx0` under Funtoo-Linux. I
...that should be `d.mon wx0`.
>>> guess I have something messy in my system. See also
>>> https://bugs.funtoo.org/browse/FL-5256.
>> Anyone running Funtoo or Gentoo? Thank you for any hint.
* Maris Nartiss <maris.gis at gmail.com> [2018-07-11 12:43:09 +0300]:
>Hello Nikos,
>d.mon wx0 && d.rast map=mymap works just fine on my Gentoo box and
>produces a ppm file in tmp directory. Anything fancy on your box
>(Wayland)?
No(t yet!).
Special on my box is: I work with the terminology terminal emulator (depends on EFL).
Yet, I do have the same problem with all terminals I have tried (i.e., uxterm, Konsole).
.ppm is the "default", based on Cairo, right?
>I have wxpython-3.0.2.0 with wxGTK-3.0.3
What are more fundamental dependencies for Graphics? The standard Linux
graphics stack? Is there any special dependency to X, to Mesa, Cairo, to
GLX perhaps?
My laptop has a integrated Intel graphics card, nothing fancy with the
hardware.
Note, while the GRASS GIS GUI works, I do observe many glitches in my system.
Like, zoom in or out, does not refresh properly the display. The "new"
map is rendered on top of the old, resulting in a noisy image.
Thank you Maris.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180711/4df4b9a7/attachment.sig>
