[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Sat Jul 14 00:31:45 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hellik):
 Replying to [comment:62 hcho]:
 > Replaced wingdi.h with windows.h in r72980. Copied from nviz.h. Weird,
 according to https://docs.microsoft.com/en-us/windows/desktop/api/wingdi
 /nf-wingdi-swapbuffers, SwapBuffer is defined in wingdi.h.
 see
 https://wingrass.fsv.cvut.cz/grass75/x86_64/logs/log-r72984-191/error.log
 GRASS GIS 7.5.svn r72984 compilation log
 Started compilation: Fri Jul 13 15:43:43     2018
 Errors in:
 /c/msys64/usr/src/grass_trunk/lib/ogsf
 /c/msys64/usr/src/grass_trunk/lib/nviz
 /c/msys64/usr/src/grass_trunk/misc/m.nviz.image
 In case of errors please change into the directory with error and run
 'make'.
 If you get multiple errors, you need to deal with them in the order they
 appear in the error log. If you get an error building a library, you will
 also get errors from anything which uses the library.
 Finished compilation: Fri Jul 13 16:35:26     2018
 and the
 [https://wingrass.fsv.cvut.cz/grass75/x86_64/logs/log-r72984-191/package.log
 compilation log]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:63>
