[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Sat Jul 14 04:45:00 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hcho):
 Commented out that line in r72986 until I can figure out what's going on.
 I'll try to compile it myself on Windows. I think -lgdi32 is missing
 there.
 Replying to [comment:63 hellik]:
 > Replying to [comment:62 hcho]:
 > > Replaced wingdi.h with windows.h in r72980. Copied from nviz.h. Weird,
 according to https://docs.microsoft.com/en-us/windows/desktop/api/wingdi
 /nf-wingdi-swapbuffers, SwapBuffer is defined in wingdi.h.
 > see
 https://wingrass.fsv.cvut.cz/grass75/x86_64/logs/log-r72984-191/error.log
 > GRASS GIS 7.5.svn r72984 compilation log
 > Started compilation: Fri Jul 13 15:43:43     2018
 > Errors in:
 > /c/msys64/usr/src/grass_trunk/lib/ogsf
 > /c/msys64/usr/src/grass_trunk/lib/nviz
 > /c/msys64/usr/src/grass_trunk/misc/m.nviz.image
 > In case of errors please change into the directory with error and run
 'make'.
 > If you get multiple errors, you need to deal with them in the order they
 > appear in the error log. If you get an error building a library, you
 will
 > also get errors from anything which uses the library.
 > Finished compilation: Fri Jul 13 16:35:26     2018
 > and the
 [https://wingrass.fsv.cvut.cz/grass75/x86_64/logs/log-r72984-191/package.log
 compilation log]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:64>
