[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Mon Jul 16 00:47:27 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hellik):
 Replying to [comment:72 hcho]:
 > Confirmed that wingdi.h compiles fine on my VM. r72987 has wingdi.h and
 OGSFDEPS. Thanks for testing. Could you try to run m.nviz.image with your
 current build (reverted r72986 and added OGSFDEPS)?
 see winGRASS compilation at r72990
 [https://wingrass.fsv.cvut.cz/grass75/x86_64/logs/log-r72990-193/error.log
 log]
 GRASS GIS 7.5.svn r72990 compilation log
 Started compilation: Sun Jul 15 14:58:56     2018
 Errors in:
 No errors detected.
 Finished compilation: Sun Jul 15 15:34:00     2018
 compilation works now; output can be tested now in winGRASS
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:74>
