[GRASS-dev] [GRASS GIS] #3600: m.nviz.image doesn't produce any output
GRASS GIS trac at osgeo.org
Mon Jul 16 13:53:50 PDT 2018
  Reporter:  guano        |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:
 Component:  Default      |    Version:  7.0.4
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  MacOSX
Comment (by hellik):
 Replying to [comment:74 hellik]:
 > Replying to [comment:72 hcho]:
 > > Confirmed that wingdi.h compiles fine on my VM. r72987 has wingdi.h
 and OGSFDEPS. Thanks for testing. Could you try to run m.nviz.image with
 your current build (reverted r72986 and added OGSFDEPS)?
 > see winGRASS compilation at r72990
 [https://wingrass.fsv.cvut.cz/grass75/x86_64/logs/log-r72990-193/error.log
 log]
 > GRASS GIS 7.5.svn r72990 compilation log
 > Started compilation: Sun Jul 15 14:58:56     2018
 > Errors in:
 > No errors detected.
 > Finished compilation: Sun Jul 15 15:34:00     2018
 > compilation works now; output can be tested now in winGRASS
 now tested with
 System Info
 GRASS version: 7.5.svn
 GRASS SVN revision: r72990
 Build date: 2018-07-15
 Build platform: x86_64-w64-mingw32
 GDAL: 2.2.4
 PROJ.4: 4.9.3
 GEOS: 3.5.0
 SQLite: 3.17.0
 Python: 2.7.14
 wxPython: 2.8.12.1
 Platform: Windows-10-10.0.17134 (OSGeo4W)
 C:\>m.nviz.image elevation_map=elevation output=D:\temp\mnviz\elev
 perspective=15
 Loading raster map <elevation at PERMANENT>...
  100%
  100%
 Translating colors from raster map <elevation at PERMANENT>...
  100%
 WARNING: Unable to get image of current GL screen
 ERROR: Failed to write image
 perspective=15 format=tif
  100%
  100%
  100%
 ''g.gisenv set=DEBUG=3'' log attached
Ticket URL: <https://trac.osgeo.org/grass/ticket/3600#comment:75>
