[GRASS-dev] Mixing vector and Raster input maps for a module
Nikos Alexandris
nik at nikosalexandris.net
Fri Jul 27 03:29:25 PDT 2018
Dear all,
I am concerned about mixing Vector and Raster maps as inputs in a
module. I think it's less of a complication if a module considers either
only Vector or Raster maps as inputs.
Should I just not worry and mix these? The question is about user-friendliness.
If tha add-on is exposed to QGIS, non-experienced users will be able to
use it. Should they be forced to think about doing some rasterisation
themselves? Or should the module do this job for them?
This is a generic question. I much appreciate your thoughts.
Nikos
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20180727/61b081c1/attachment.sig>
